Hello all, the New Jersey fall/winter has been brutal this year. I started this job just around hurricane Sandy, and just will now consider this complete. I got tired of waiting for a perfect day, so with a little snow still around, I decided to test it out. It started, as it should, and being it was near 25F out, I gave it a bit of time to warm up prior to moving it. As you can see, there is still some snow around. It snowed yesterday too and will again tomorrow, so I am glad I slipped in one ride. I did not push it at all, due to the tires will not grip in this weather unless thoroughly warmed. I have been down that road in my Viper on Christmas eve several years ago. My neighbor still looks at me funny as he watched me going sideways down the block with my Santa Claus hat on. It was like I was in a drifting competition. I really didn't try to get it so crossed up. Anyway, as a manual the first thing I noticed was a different throttle response. If you read back, you will see I changed the Motronics to manuals, while also chaning to the CS type exhaust. I think both items contribute to the "snappy" throttle. The sound from the new exhaust is nice. It is better than stock, IMO, but the difference from stock is not as noticible as a Tubi or Capristo. Either way, I like it better than the tremondous and quiet stock muffler.
The second thing I noticed, is that during take off, the car no longer wants to "jerk". With the F1, I had to carefully apply the pedal to take off smoothly, if I was careless, it would buck. I am not sure if the PIS was set wrong, or if it was my technique, but it used to buck. No longer, I can take off as well as I expect I should. The gear changes are clean and positive. The gated shifter is very fine compared to most other cars. There is nothing vague about it. Now that I have seen the inner workings, I feel the Ferrari shifter assembly is superior to other manual shift arrangements. The cable operated mechanism allows the motor to "torque over" without the fear of side pressure on the shifter. In the Viper, the motor moves a lot due to the tremendous torque the motor makes. Many people have hit 2nd, while intending to hit 4th. In 4th you are well into triple digit speed. To accomodate this you have to flip your hand and position your arm. No such tricks are needed in the Ferrari.
The pedal placement makes heel/toe easy. I can see this was thought of when designing this car.
I feel the "personality" of the car has changed dramatically. I like it. I must say, the F1 arrangement is a terrific item. It is a clever piece of engineering. If I did a lot of track events, the F1 would probably be best.
Being my free time is limited, I want to enjoy my drives the best I can. I feel the gated manual allows me to be a little more involved. I will say, I now like this car better than when it had the F1.At most speeds, I can shift faster than the F1. Once past say 6000 rpm, that changes. The F1 is simply faster at high revs. I have done a few things to personalize it while I was at it. Like the yellow calipers and matching ignition key, tit wheel lugs and a steering wheel on order. I spoke with Rod from FAI, and he said he can program my gauge cluster back the way it was as an F1 as easily as he made it for a manual.
So, now that this is done, and I have a summer of gated shifts ahead, was it worth it? I feel it was, as I longed for a 3 pedal arrangement. I felt the conversion had less drama than selling my car, and finding a similar one with 3 pedals. I however have the ability to do more than 95% of the work myself, actually, the only thing outsourced was the gauge reprogram.
If someone were to take this on with buying all new parts for the conversion, and paying an hourly shop rate to do the work, it simply would not make sense. The cost would be prohibitive.
However, being able to hunt up good used assemblies, and doing my own work, the cost was not bad. If I were inclined, I could offset a big chunk of it by selling my F1 assemblies that I removed. This conversion is easily and completely reversible, which gave me peace of mind.
In closing I want to thank Eric, Taz and Stef, who gave valueable input. Without Eric, I would not have even attempted this.
I also want to thank everyone who had an interest in this project. It actually helped keep me motivated. I have read many times this "could not be done". I needed to find out for myself. Don't believe everything you read on the internet. Uhh, Bon Jour!
Kind Regards
Rich
