Hello all, I am in the midst of a project, and unfortunately I do not have access to a 3 pedal 360 to obtain the info I need. I was hoping someone could perform these simple tests and post the result.
If the car is placed in neutral, and you attempt to start the car without depressing the clutch, does the motor crank? If so, does it start?
If anyone is inclined to try the above in gear, or has previously done this by accident, those results too would be helpful.
I am in the midst of a conversion project, and I am trying to understand exactly what the clutch pedal switch actually acts upon. Simply looking at the wiring diagram is leaving me with as many questions as answers.
Thank you in advance for any input. I appreciate you taking the time to perform the "test'.
Kind regards
Rich
Kind regards
Rich
