Wondering if any of you have come across a problem like this. It was fixed about a year ago and has broken again.
Basically there is a nut/bolt that is attached to a hydraulic behind the driver seat which lower and raises the soft top. The hydraulic is bolted onto the frame of the soft top by a nut/bolt. The nut/bolt has broken into two and the thread bit stuck in the frame. The workshop has and I guess will be able to solve the problem again but just wondering if this is a common problem. Dont really want it to occur again and wondering if there is a stress point that has caused the bolt to break for the second time.
