A decent header from a reputable builder will set you back quite a few more dollars. If there is some evidence of the fabspeed headers (regardless of who actually builds them) failing, that would be important, I have seen no evidence of that.
A decent header from a reputable builder will set you back quite a few more dollars. If there is some evidence of the fabspeed headers (regardless of who actually builds them) failing, that would be important, I have seen no evidence of that.Well you didn't because your so-said Fabspeed headers were produced 100% by Jim Technologies in Taiwan, shipped to Fabspeed in the USA (at 700USD), and shipped to you in NZ (at 3000USD)...That's a lot of shipping...:yikes:
I hope you'll still be happy with these headers in 50.000km![]()
It has been established that the headers are made in Taiwan.The only thing that is made in the USA is the sticker price and for that Fabspeed should be ashamedHowever I see there are strange comments on this forum regarding them being made in China/Taiwan, it is true that the well made "lost wax" cast stainless flanges that are used come from the orient, the rest is made in the USA!
Inconel headers will cost you about twice as much as quality stainless steel. If you get headers made out of high grade steel alloys and then ceramic coat them, they will last. The key is heat dissipation. The problem with heat shields on headers is that they trap heat around the headers. This causes the headers to get even hotter, which in tern heats up the heat shield more. Ceramics take a while to heat up and when they do, it takes a while for them to cool down. They release heat slowly, which is why ceramic coatings are great for headers. Cooler engine bay temps help the longevity of all the parts in the area and help keep intake temperatures down, resulting in a more efficient engine. Will you notice any of this? Probably not unless you have a huge problem with heat or actually measure it with a thermometer.Thank you most informative.
I hear that Inconel headers will cost me a second mortgage on my house which I can ill afford
Check the compression and leak down numbers. Ditch the cats while you are in there, they are the source of the problem.I have a cracked left side manifold on my 1997 F 355 as evidenced by the insulation fibers that are in my engine bay. I drove the car prob 30 miles before I noticed the issue. Is is possible I damaged anything in the motor?been kind of worried about this....Having them replaced with Nouvalari manifolds next week.
Which cats would you suggest? At some point, was thinking of using Nouvalari's.Check the compression and leak down numbers. Ditch the cats while you are in there, they are the source of the problem.
What year car?Which cats would you suggest? At some point, was thinking of using Nouvalari's.
Also, is using test pipes bad for the car in any way, and will I have to re-map the ECU perhaps if I bypass the cats or use test-pipes? And oh yes....I have also heard of non OEM cats throwing more SDL and CEL's. Isn't there a spacer one can put on the sensors to avoid throwing the codes?
I am in a cash crunch, but would do the cats too if I had the $. I want to sort this car out!
You have been told wrong, it is possible. How do I know? I have a 1997 F355 running w/o cats and it does not throw codes.What year car?
**edit, see its a 1997** i have been told deleting cats out the 5.2 is impossible. I wanted to as well but it seems to cause other issues. Novari are not going to be the cheapest option.
Expensive but worth it to have the ecu programmed the way I wanted it. Fabspeed got it right for me. I am running without cats with a custom exhaust.Which cats would you suggest? At some point, was thinking of using Nouvalari's.
Its a waste of money to buy Tubis with so many other options...The factory headers on my 1995 F355 lasted 41,000 miles. Just last week I started seeing bad symptoms of cracked headers. Now I'm trying to get the Tubi replacements. Sigh, time to sink 8 thousand more into my 60 thousand Ferrari.
