355 adjustable suspension question.
1383 Views 3 Replies 3 Participants Last post by  f355alldaylong
hello, what adjustments can be made to the 355 suspensions? ride height? i ask because i see some that have the front ends "lifted" as apposed to others that the front seems quite low.
thanks for your time!! :)
The F355 suspension has two settings (normal and sport). A small switch on the upper left hand corner of the center consul switches between the two settings. You would not notice a difference in front end height between the two settings.
The cups that hold the springs in the McPherson struts at the front can be adjusted for ride height. You have to dismantle the suspension assembly and then wind the cups on the threaded strut leg. Do remember how many turns you do because it will be a trial and error on what is the most acceptable height for you. The rear too can be adjusted in a similar way.
355
cool, so the ones that looked lower have probably had the pearches adjusted.
thanks!
