The brake cable was not so easy took me a good 2 hours to hook back up
For some odd reason the right rear Park brake cable became unhooked and was just hanging there, so I finally got around to it (very tedious)
I had to remove the left rotor loosen the brake cable and try to refit the cable and hook together, finally I did it after I ran out of vulgarity...
Took some pics of the procedure hope this helps someone down the road.
1 pic shows the cable disconnected the next
2-3- show the progression from removing the caliper make sure you hang it with a coat hanger don't let it dangle
4-removing the rotor
5-6- the cable without and with the cover housing
7-where the cable has to go to refit into the hook for the park brake
8-location of where the two have to join not easy
9-where to loosen the park brake cables
10- the finished product PHEW!!!
_______________________________________________________
Night life........ain't a good life........but it's my life -- Willy Nelson...
