Hi All,
My 328 just cranks and cranks but will not start. Any idea's? I'm thinking coil?
Thanks,
Marc
Hi Marc,
You need to figure out whether it is a fuel or spark problem. One easy way to do this is to spray some carb cleaner in the intake (brake clean won't work). You can remove the bellows at the air cleaner and spray in there. Or just spray some in through the NASA duct on the side of the car. If the car fires on carb cleaner, your problem is fuel system. If it won't, the problem is spark. Then the fun begins. Let us know which it is, and we'll help out. I assume you've checked all the fuses already? Also check the two main engine harness connectors near the top of the oil cooler. Mine were about to come apart. -Steve
