I have a 328GTB and I think that when it gets a little hot coolant comes out of the overflow tube onto the driveway. I'm not sure if this could be an issue with the coolant tank cap or not. Any thoughts?
Yup...too much coolant
Radiator air bleed
You can try bleeding the radiator.
Open the front bonnet and at the top of the rad (can't remember which side), there is a small thumbwheel tap.
With the car warmed up and engine off, unscrew the tap and bleed out the air until coolant is expelled. Shut the tap and you're good to go !
Best Regards,
Gar.
2 x 328GTS (one in UK, one in USA)
