Hello Guys,
I finally had the chance to replace the timing belts. Doing the job takes time to do it. This site helped me a lot. I really appreciate this GREAT site.
Now that I replaced the belts and the tensioner bearings. I run into a problem finding the torque setting on the #1 Tensioner bearing nuts? #2 Tensioner block nuts? #3 Camshaft journal nuts Which I removed and I use a matchbook cover to lock the camshaft from moving when I remove the belts. I learned that from this site too. #4 Camshaft/valve cover nuts? I looked at the manual but I cannot find these settings. I'm looking at the wrong places I know. Somebody out there know where to look or have done this kind of things.
Thank you,
Rudy Javier
Stockton California U.S.A. :work:
Thank you,
Rudy Javier
