Looking at the common setups,
300/250 = 1.2
350/300 = 1.166
400/350 = 1.14
450/400 is 1.125
Thanks! I figured you already had the info :thumbsup:Remembering back I think
Front = 6.0/3.5
Rear = 6.0/5.5
I think.
But obviously there is more to it than just that as the springs also affect the f/r weight transfer and roll stiffness. I think the ideal f/r ratio is around the 1.8 to 1.2 point....but that's fro the way I drive so.......
If I understand your correctly, for 6" of front wheel travel, the spring travels 3.5"?
I didn't think that the angle of the rear shock was such that the motion ratio would differ that much from 1:1.
Anyway...
For the spring rate combos listed above, these are the wheel rate combos:
Code:
Front Rear
Wheel Travel 6 Wheel Travel 6
Spring Travel 3.5 Spring Travel 5.5
Spring Wheel Spring Wheel F/R Ratio
300 175 250 229 0.763
350 204 300 275 0.742
400 233 350 320 0.727
450 262 400 366 0.715
