82 308, Do you have to take off the AC unit to get the water pump housing off?
thanks RC
Water Pump
The answer is no, you do not have to remove the A/C compressor. You might have to remove the rear cam belt cover to get access to two bolts, but that's about it. A water pump is actually easy to do on a 308 Ferrari! Just not cheap. -Steve
But?
thanks for the reply,The bolts of the AC pump go thru the belt cover....
