My oil pressure gauge reads constantly low, I have a new pressure sensor ordered and will replace it in hopes of remeding the issue. On the other hand it could be the gauge, does anyone know the operating voltage of the sender to gauge? i.e. I assume as the presuure increases the voltage to the gauge does as well, can anyone confrim this. Thanks
Summary of Veglia requirements:
Oil pressure:
Full scale 68 ohms to ground.
Top of red area 360 ohms
Zero PSI 470 ohms
(Reverse scale due to meter mounting upside down)
Temperature:
Bottom of red area 19.7 ohms
Bottom of scale 198 ohms
Fuel
Full 44.5 ohms
? 134.5 ohms
Top of red area 276 ohms
Empty 376 ohms
Voltage
Left end 11.22 Volts
First tick 12 Volts
Second tick 14.6 Volts
Right end 17.7 Volts
Excellent - Exactly what I was looking for, luckily I have a resistence simulator for work so will test it out. Thanks very much!!
Odds are, it's your sensor that's faulty, and not the gauge. I just changed mine, and it reads perfectly.
