Well I pulled the motor out of my 308 last week to finally do an inspection and rebuild.
A couple of questions I have, hopefully someone can answer.
My Fcar mech. told me that I need to replace all of the following:
1. Pistons & liners
2. all main and rod bearings
3. all valves, guides, seals, and springs
4. have the block line bored.
My question to you is that he doesn't know the condition of my motor except what I have told him in the past, so why do you need to replace all of the above?
Sure, if it's not your $$ why not tell someone to replace everything?
I'm not saying it doesn't need those things, but shouldn't it be inspected and tolerences measured before just replacing everything?
The reason for pulling it is that it was starting to smoke upon acceleration. It had been smoking only on re-acc. after going down a hill (valve seals?)
Also it was leaking oil quite a bit as well. Also starting to burn oil.
The wierd thing about all this is when I pulled the plugs out they were a nice light brown color even though upon acceleration their would be a big blue cloud following me.
As far as I know the motor has never been touched ( I figured this out when dis-lodging the heads). It had 64000 miles on the car when I bought it and have put over 5000 miles on it myself.
What should I do? My mech. told me it would cost me almost $10000 if I rebuilt it myself (putting it together and back in the car after machine work). Does this sound right?
Can't the cylinders be honed to a 1st or second oversize?
All new valves?
Any response would surely help
rivee
1. Pistons & liners
All new valves?
rivee
