Just bought a 1979 308 GTS last week and encountered an electrical problem that seemed to fix itself after a few days but am worried if it comes back.
At first the driving lights went out, then the wipers, electric windows, brake lights and indicators went out, and then worked again after a long drive.
The lights just turned out to be a faulty relay. I was just wondering if the other things have a common connector which may be loose? or if i should just forget about it. I just want some advice before i pull the dash apart.
Also the alternator/water pump light randomly turns on, the batteryworks fine and i have checked the belt tension and it seems fine also. The timing belts were recently changed so that could just be a connector fault im guessing.
Thanks in advance.
Thanks in advance.
