1 - 20 of 54 Posts
· Administrator
I've never driven the McLaren :cry: (obviously), but it is suppose to improve the feel of the car as you are centered in the car much like a racecar.
Should they do it? I have no idea really. If the seating position were to improve the car as a whole then yes.
i believe the easyiest way to get out of a mac was at the left side, well that's the only way that i've seen people get out of a mac
and man, it seems that i totally forgot to take an interior pic of the 365P
i saw the car at Pebble & FCA Concours, and not a single interior shot???? :eek: :evil: at myself
· Administrator
Discussion Starter · #17 ·
I believe at least two were produced. Here is the write up from Ferrari:
365 P Speciale (1966)
In 1966, Pininfarina built a three-seater berlinetta over a V12 mid-engined sports-prototype chassis (4,390 cc, 380bhp). It created a huge furore. This once-off was built to order for Gianni Agnelli and was followed a year later by another special model for Luigi Chinetti. The 365 P Speciale boasted a more harmonious version of the lines of the Dino prototype. The headlights were faired in and the roof was made from Plexiglass for a brighter cockpit. This was also the first time that the characteristic star-shaped five-spoke alloy wheels made an appearance.
Technical specification
Model 365 P SPECIAL
Engine Rear-mounted 60° V12, light alloy cylinder block and head
Timing gear 2 valves per cylinder, 1 overhead camshaft
Bore and stroke 81 x 71 mm
Unitary and total displacement 365.86/4,390.35 cc
Compression ratio 8.8:1
Maximum power 380 bhp at 7,300 rpm
Transmission Multi-plate clutch, 5-speed gearbox + reverse
Chassis Tubular
Front suspension Independent
Rear suspension Independent
Length 4400 mm
Width 1890 mm
Height 1190 mm
Wheelbase, front and rear track 2600/1480/1470 mm
Kerb weight 1,020 kg
Model 365 P SPECIAL
Chassis Tubular
Length 4400 mm
Width 1890 mm
Height 1190 mm
Thanks, Boxer. :)
Yep, there are 2 cars
s/n 8815 & 8971
the car that i posted pics of is 8971
that one has always, and still is, belonged to the Chinetti family
not sure where the other one is, that might be the one from Texas that you are reffering to Boxer
1 - 20 of 54 Posts
