WHERE DO YOU STAY BY?
I am near Myrtle Beach, S.C.WHERE DO YOU STAY BY?
Thank you, anyway.TOO FAR OTHERWISE I WOULDVE TOLD YOU TO BRING IT TO ME TO HAVE MY TECH LOOK AT IT
From my basic knowledge, it seems to me you can't have both smoke and no loss of oil. My first thought would be leaking thru the valve guides and my second thought would be you can't. measure the oil level that accurately on the dry sump engine, . if the smoke goes away after warm up, i would not worry about it,,, i would also pull a few spark plugs to check the color , they should be a nice coco tan, or light chocolate brown. You may only have one cylinder leaking and the valve guide closes down on warm up.
oh , one other thing , is the smoke from both side , all pipes or just one? Oh , another thought,,, it could also be coolant,, check that level, it might be a leaking head gasket , again is it all pipes or just one ?
thats my take on it , but i am not a pro,,,
It is coming from both tail pipes equally. Coolant sounds like the issue as it does not smell like gas or oil. Got to get it to a Ferrari tech!
what color is the smoke? light blue or white ? could it just be the cold air condensing the exhaust gasses?My 456M on a cold start has smoke coming from exhaust. After warmup it goes away. Over the last 1000 miles it has not used a drop of oil nor is there any leakage from underneath the car. Any suggestions would be greatly appreciated.
The smoke is definitely white and coming out of both exhausts equally. What really concerns me is the smell.It does not smell like either oil or gas. There ia a Ferrari trained mechanic about 30 miles away from me so I think I will run the car over to him.What color is the smoke? If blue then oil is leaking from the rings. If not then there is perhaps a CAT issue. but i've never heard the M having these problems albeit the CATs can be compromised.
Our older 456, had the ring problem and many complained about having to replace. Our experience was from a poorly maintained car before we got it as in we needed to replace the exhaust headers then both CATs due to an issue found too late.
The M 456 engine changed the firing order and I'm not sure about the ring problem but personally never heard they had the ring/oil problem and therefore more desirable.
I would have it checked for combustion checked.
I'm NO gearhead but smoke seems a combustion problem if smoke is NOT blueish.
That is my thought also. The car is currently with a Ferrari trained mechanic.if its not oil or gas, it must be coolant , which is always going to be white
perhaps a compression test , but its on both headers ,, still a puzzle
Yesif its not oil or gas, it must be coolant , which is always going to be white
Just give me a couple of weeks longer...on vacation now!sso what did it turn out to be?
Well, it was the valve guides. Also had full service done. The bad thing was sourcing parts with the supply issues we all have been through. But it is done, nomore smoke and engine power and response is much improved. Now on to the next project.Just give me a couple of weeks longer...on vacation now!
