Have a cherry Testarossa that runs fine when warmed up, but doesn't advance when I step on the gas pedal. Although it accelerates smoothly, it doesn't have the torque that should kick in when you step on the pedal. It did for a while, then it disappeared. The car is also hard starting.
I was wondering if this might be the sign of a bad ECU....any thoughts out there?
The car operates well when warmed up, it just doesn't have the spark advance that gives it that torque as you wind through the gears.
Any ideas would be appreciated. Thanks!
Bill
You can also direct responses to my email - [email protected]
Bill
