The TRs are not carbs so the plugs are not being fowled so this wouldn't be the problem.
Just to get some more info, when you come to a stop I'm assuming you have it out of gear and the clutch is not engaged? If so, it sounds like a fuel problem.
When you say idles fine, you mean after the initial startup in the garage?
