Greetings,
During the prepurchase Inspection on a 33,000 mile 308 two cylinders (7 and 8) had compressions of 100psi while all others were between 125 and 150 psi. The Ferrari dealer performing the inspection found no changes between a hot and cold engine or after putting a squirt of oil in the cylinders. The engine starts easily, idles smoothly and shows no smoke or water from the exhaust.
The car is immaculate in all areas but I would be interested in other owners opinion of the situation. The Dealer said it needs an "Italian Tune-up" - fresh tank of gas with injector cleaner and a fast drive of 50 miles. The dealer does not think it is a head gasket.
How concerned should I be in moving forward with the purchase?
Thank you,
Jim
Thank you,
Jim
