Hello,
I checked my thermoswitch at the expansion tank and they are open. further checking, it show that it turns on the low engine light at the dash and part of the signal goes to the electronic ignition module. This switch must be normally closed then, if it turns the light "ON" in the dash. When the coolant is cold, the timing must be delayed_ I'm not sure. Anyway, where do you purchase this coolant thermoswitch? Are they still available? If not, Is there any alternative switch to use?
Thank you Guys!!!
Rudy Javier
Stockton, California U.S.A.
:work:
Thank you Guys!!!
Rudy Javier
:work:
