I'll put this in a new thread since it went a little offtopic....
Has anybody had any experience with putting 19" rims on the f355. I have found a set originally made for the 360, making them slightly wide in the rear... I believe 11,5" wide. I heard that if you use wrong wheeldiameters it messes up the antispinsensors etc. This true for the 360? What about
f355????
f355????
heck yea you can put 19's on a 355, I have em on my 348! The only issue you may face is offset... in some cases too much offset will place the outer bead out past the wheel arches... and looks pretty stupid to most folks. The diameter is a non-issue, the overall diameter of your 19'' wheel/tire will be pretty close to stock, because the larger wheel will have a lower profile tire.
100's of guys have 360 wheels on thier 348's and 355's... NO problems!
I see, ok... The tiredude said they'd probably stick out like 2cm so I don't know... Do you have any pic's of your setup? They outside or not? How wide did you go in the rear?
