41 - 55 of 55 Posts
Discussion Starter · #41 ·
Final pics
Okay, thanx for checking out the pics. Here's the last ten pics. Hope it was worth it. w/ smiles Jimmy
Just awesome, Jimmy. Quality work - you must be VERY happy with this car and the history file you have.
I think, judging from the number plate, this was a French car before the restoration, correct? It doesn't state in the FL registry, only that it was sold to the US in 1980. Do you know anything of its early history?
Onno
Discussion Starter · #45 ·
Onno
Thanx to all, so glad that you enjoyed it. Onno, I believe this car was initially Italian registered, moved around and was in France prior to coming into Japan. w/ smiles Jimmy
I will ask my specialist. But the way I read the thread between Drew and David is that supposedly a modification was made that increased the gearbox oil capacity from 5.75 to 7.75 litres from #17743 by changing the overflow tube. David's car (which he has owned for 25 years) is #18307 but he says it does not have this modification. Question is, therefore, whether your (#18011) or mine (#17977) would have this modification. Jimmy's (#17585) shouldn't have it.
David's way of dealing with it is to fill with 7.75L but he doesn't state whether that causes an overflow. If it doesn't, it certainly seems the correct amount to put in.
Onno
· Administrator
Onno
Found this ...
For all the cars before #17747 if the modification hasn't been made, 2 more liters must be added through the top of the transfercase (plug D on the picture ).
I will ask my specialist. But the way I read the thread between Drew and David is that supposedly a modification was made that increased the gearbox oil capacity from 5.75 to 7.75 litres from #17743 by changing the overflow tube. David's car (which he has owned for 25 years) is #18307 but he says it does not have this modification. Question is, therefore, whether your (#18011) or mine (#17977) would have this modification. Jimmy's (#17585) shouldn't have it. Onno
To clarify, my 365bb is after the supposed modification date, yet did not have the modification.
David's way of dealing with it is to fill with 7.75L but he doesn't state whether that causes an overflow. If it doesn't, it certainly seems the correct amount to put in. Onno
I've been adding an extra 2 litres of gear oil for about 25 years. No issues with overflows and my breather is just a short tube (<15mm) from the case.
41 - 55 of 55 Posts
