Testarossa stalls in 2nd gear - Ferrari Life
post #1 of 4 Old 02-23-2014, 09:26 AM Thread Starter
Ferrari Life Posts: 1
I have 1989 testarossa, when going form when going into 2nd gear it stalls when I let the clutch up! only happens when going into 2nd from 1st. Is fine coming down the box. Any ideas?
chrissage is offline
post #2 of 4 Old 02-23-2014, 05:41 PM
Ferrari Life Posts: 9,567
wetpet is offline
post #3 of 4 Old 02-24-2014, 09:11 AM
There is no direct correlation between the operation of the injection system and the gear selected. If the fuel injection system is out of whack and has difficulty catching it's self and stabilizing idle speed and you are slower to make the change into second than any other gear, I would say that would be the only correlation that would make sense.
Does the car have a difficult time keeping idle at any other time? Are you only noticing this issue when the engine is still cold, does it go away when warmed up? Does it do it with the A/C running and/or if off?
post #4 of 4 Old 02-28-2014, 05:25 PM
360 Modena's Avatar
Ferrari Life Posts: 4,515
Never happens on my TR. What is the idle RPM and do you have a/c compressor on?
360 Modena is offline
