Why would a Enzo XX sound so different... - Ferrari Life
post #1 of 9 Old 05-11-2013, 06:31 AM Thread Starter
Pablo's Avatar
Ferrari Life Posts: 815
than a Enzo Ferrari? what is it exactly that makes such a big difference?
Current:F12, F40 , F50 , Enzo , Mclaren P1
Past: 348 spider ,F430, Dino 246 GTS
Waiting: Ghost 2016.
Pablo is offline
post #2 of 9 Old 05-11-2013, 08:28 AM
Ferrari Life Posts: 63
Pablo,
I would image it has a lot to do with the exhaust. I also am under the impression that the XX revs higher than the Enzo. But that's just one mans opinion. I could be wrong I have been before.
Izmar21 is offline
post #3 of 9 Old 05-12-2013, 08:35 AM
Ferrari Life Posts: 310
Different (open) exhaust & longer duration camshafts. Enzo peak power at 7800rpm, FXX at 8500rpm & FXX Evo at 9500rpm.
C311 is offline
post #4 of 9 Old 05-12-2013, 09:10 AM Thread Starter
Pablo's Avatar
And you think that is the basic reason why it sounds so much nicer?
Pablo is offline
post #5 of 9 Old 05-12-2013, 10:15 AM
Sw4n's Avatar
Ferrari Life Posts: 106
Consider that the FXX is a racing car so basically it doesn not need silencer...
"Engines are like women: you have to know how to touch them in the most sensitive parts."
Sw4n is offline
post #6 of 9 Old 05-12-2013, 11:07 AM Thread Starter
Pablo's Avatar
So the Enzo has a silencer?
Pablo is offline
post #7 of 9 Old 05-12-2013, 12:13 PM
Sw4n's Avatar
As far as I know every road car must have muffler in order to reduce the noise, according to dB limit established by law. So also Enzo must have some kind of silencer. For example I also own a 1996 Royal Enfield 350cc. If I run it without silencer is as noisy as hell, unbelievable... Far more noisy than my GT4. And it is just a 20hp monocylinder 350cc!!
Race cars follow different and less strict rules (but also circuits has noise limit) so the exhaust system is more open and so noisier.
Sw4n is offline
post #8 of 9 Old 05-13-2013, 02:00 AM
The legal noise limit for modern road cars is 74dB at 50 kmh in 2:nd and 3:rd gear. Cars must be silenced to 75% of the peak hp. Example: Enzo peak at 7800 rpm so it must be quiet up to 5850 rpm. Above that rpm the exhaust system valves can open and bypass the silencers. The main reason for the valves is to keep silencer temperatures down and to avoid setting the car on fire after some hard driving. More aggressive camshafts make more power but also more noisy engine and also increase emissions. Enzo have 27.5 rpm controlled advance on the intake camshafts and 25 rpm controlled retard on exhaust camshafts to max out available power, low to high rpm and to manage emissions and also noise. Camshafts are adjusted by a separate oil pressure system, powered by an oil pump at the end of the left intake camshaft, controlled by Engine Control Units and activated (power on-off) by electric solenioid valves. FXX dont need to be road legal so noise and emissions are not an issue. Simply speaking, the FXX engine have much in common with the "A1GP by Ferrari" engine (8 cyl x 1.5 = 12 cyl)
C311 is offline
post #9 of 9 Old 05-13-2013, 02:37 AM Thread Starter
Pablo's Avatar
Thanx Thomas , very nice explanation!!!
Pablo is offline
