456M immobilizer bypass - Ferrari Life
post #1 of 31 Old 01-15-2015, 04:46 AM Thread Starter
P2164's Avatar
Ferrari Life Posts: 1,194
I've read a thousand posts on the impossibility of bypassing the immobilizer but decided to have a look at the circuit and components. The 456M doesn't have a true wiring diagram but a block diagram with plug and pin locations so with the help of those and tracing wires I got a pretty good idea of how the system works and its complicated even for a electronic tech like me. Seems the immobilizer sees a signal from the fob and if the codes match it turns on a relay in the immobilizer enabling the start relay and produces a signal to the immobilizer interface which in turn sends a digital signal into a processor built into the Motronics EFI ECU on pin 56 of both left and right ECUs, when the ICs built into the ECUs sees the correct digital signal it turns on the relays for the left and right injection and ignition supplying voltage to the injectors and coils. A simple thought would to be just jumper relays for start coil and supply voltage and it would work but it will not. The injectors and coils are trigger by grounds (a negative signal) which comes from high current switching ICs which are turned on by the IC that gets the signal on pin 56 of the motronics ECUs. In short I spoke with a tech at ecudoctors.com which rebuild motronic ECUs, and the secret is to find the input to the ICs which turn on the ignition and injection and supply them with a constant signal, plus bypass the start relay located in the immobilizer unit. I opted to send the entire system to ecudoctors and let the pros look at it. Will keep you posted. I know there are many who would not agree with my wish to eliminate the immobilizer but to each his own, I don't like it and don't like being held captive by a 4 digit code and a fob. Which brings to question, where are all the original fobs since there are so many guys with just one? Seems they would not be any use to anyone but the owner of the car. Must be a pile of them someplace.
A bunch of stuff.
P2164 is offline
post #2 of 31 Old 01-15-2015, 05:35 AM
Ferrari Life Posts: 2,206
Jack, good on you for trying to sort this. It's something Dave & I have considered looking at too, but have had our hands full with other things lately.
I hope the ECU docs can come up with something.
About the original fobs laying around; it's unfortunate, but you always see a few for sale on eBay, and I can't help but wonder how many of these weren't included in the vehicle sale, and how many "new" owners have missed out on getting all the original fobs for their cars?
There was a guy who posted recently that he's trying to find the new owner of his old Ferrari so that he can "sell" him the additional fobs. Why didn't he include them in the sale? These really ought to be gifted to the new owner
post #3 of 31 Old 01-15-2015, 05:57 AM Thread Starter
P2164's Avatar
Amen to that!
A bunch of stuff.
P2164 is offline
post #4 of 31 Old 01-15-2015, 08:07 AM
silly's Avatar
Ferrari Life Posts: 269
What gets me is also all the owner manuals being held hostage on ebay that came with the cars
Keep the car as one
94 F348 Challenge
95 F355 Challenge x 2
97 F355 Spider
silly is offline
post #5 of 31 Old 01-17-2015, 06:29 PM
Ferrari Life Posts: 327
Is the 456 a Vette killer?
Hows about a general report on this model? Yo Da Man!
reggazz312t is offline
post #6 of 31 Old 01-18-2015, 03:20 AM Thread Starter
P2164's Avatar
Reg they received all the components on Thursday, no report as of yet but I must say I can't wait to find out the results.
P2164 is offline
post #7 of 31 Old 01-18-2015, 10:14 AM
Jack- Did you send them a Motronic ECU, too? The other piece of the puzzle is that the Alarm ECU passes a clear to start signal to the Motronic DME that must match what the Motronic has stored in memory.
post #8 of 31 Old 01-18-2015, 01:38 PM Thread Starter
P2164's Avatar
Yes, both ecu's and the immobilizer plus immobilizer interface.
P2164 is offline
post #9 of 31 Old 02-27-2015, 02:56 AM Thread Starter
P2164's Avatar
An update, that clear signal that you mentioned Taz is coded as you said and from what was explained to me comes in the form of lines of information, example a-z, on Porsche immobilizer the information to start the ignition sequence could be on line U and the fuel injection on line R and they know what to do to bypass after they find which line has which information. The motronics ecus are the same but the line of information are different between Ferrari and Porsche. One of the big hold ups is they didn't want to damage my system I sent by experimenting with it, I thought that was thoughtful so I purchased a complete additional system from a totaled 456M and gave them the go ahead to do what ever. Once they find those lines of information this will open up the doors for everyone who wants to bypass the push button fob. The turn around will be a couple days. They sent me this short clip of the motronic unit in operation, the motronics test unit is awesome. https://www.dropbox.com/s/ezoe08mx14...13221.mp4?dl=0
For you geeks like me look to the left of the flashing lights, you will see where they can dial in O2 sensor voltage inputs, in closed loop operation it will change injector pulse width and throw engine check lights which I assume they can watch. Cool test unit.
A bunch of stuff.
P2164 is offline
post #10 of 31 Old 02-27-2015, 09:28 AM
Jack- Sounds like they are making progress. The PIN is memorized by the right Motronic DME and the signal sent by the Alarm ECU must match that PIN. If you swap alarm boxes for new ones with a new PIN, it is necessary to swap the virgin left Motronic DME or buy a new Motronic ECU or she will not start. One other thing to bypass.
post #11 of 31 Old 02-27-2015, 10:28 AM Thread Starter
P2164's Avatar
Good information Terry, I will remember this! So when the new immobilizer and ecus (from the same car) show up and after installation it doesn't start swap the ecus, correct?
P2164 is offline
post #12 of 31 Old 02-27-2015, 10:30 AM
Jack- Affirmative, and hope somebody else did not already do that. Odds are they did not.
post #13 of 31 Old 02-27-2015, 12:27 PM
Taz, I think what you said may be true for the later generation Motronics, but on the 5.2's that Jack & I have, I don't think it's entirely correct.
During the development of the Cat ECU replacement, I was testing an industrial thermocouple signal converter, and at startup, for a second or two it put alternator voltage on the 5v cat signal input of my right hand 5.2 Motronic, and let the smoke out
I then replaced the hosed Motronic with a used unit from a salvage 550, and it worked fine, with no immobiliser or alarm issues.
post #14 of 31 Old 02-27-2015, 06:35 PM
John- 50-50 odds you got a left Motronic ECU.
post #15 of 31 Old 02-28-2015, 01:07 AM
That's a possibility!
post #16 of 31 Old 02-28-2015, 03:10 AM Thread Starter
P2164's Avatar
John, Terry, has anyone ever bypassed the immobilizer? I've read some posts from programmers who own Ferraris on this site and they mention the code but no one has confirmed it being done. Or am I missing something?
A bunch of stuff.
P2164 is offline
post #17 of 31 Old 02-28-2015, 04:20 AM
Jack, I've not heard of it being done yet.
post #18 of 31 Old 02-28-2015, 04:45 AM Thread Starter
P2164's Avatar
John I might be just burning dollars, we will see.
P2164 is offline
post #19 of 31 Old 02-28-2015, 05:23 AM
Keep at it Jack, I don't think the planets have ever been this close to aligning.
I think/hope you'll be able to pull this off.
post #20 of 31 Old 03-17-2015, 06:40 PM
Jack,Ive got the unit from a qv Mondial C,,,bent valves,,unit out,,,,pics coming.$25,,,,decent Car and cool project.No hurry and fair price.Perfect for Pizza......Owner wants me to "place Car"...
