Holley Hydramat Fuel Tank Pickup - Ferrari Life
post #1 of 7 Old 12-12-2014, 11:20 AM Thread Starter
Ferrari Life Posts: 2,204
This stuff is ubercool:
https://www.youtube.com/watch?v=N_jsSPRUTSA
Mark, you need this for your build with the G's you'll be pulling
post #2 of 7 Old 12-12-2014, 01:39 PM
Very cool. Looks like the filtering to flow capability is far superior to anything else commonly used right now. I'd like to see how long that mat will last for and if it ever degrades and what the particulate quantity is if it does physically degrade. I'm figuring you'd still want to run a traditional fuel filter down stream just in case.
post #3 of 7 Old 12-13-2014, 04:46 AM
mk e's Avatar
Ferrari Life Posts: 4,439
I wonder what that stuff is?
mk e is offline
post #4 of 7 Old 12-13-2014, 12:37 PM
John, Josh, Mark- In the space vehicle world we call that a propellant management device (PMD) and that one seems to work very well. In zero gravity, fuel in a propellant tank tends to form a sphere in the center of the tank, well away from traditional fuel pick-ups in tanks. Solutions are to do a settling burn with the attitude control system to get the fuel over the traditional pick-ups, or use a PMD like this one. Wonder if they got it from aerospace sources or if the aerospace community might be able to use this version?
post #5 of 7 Old 12-13-2014, 02:25 PM
Terry, sounds like an over complicated and expensive system unlike this mat!
post #6 of 7 Old 12-13-2014, 02:50 PM
Josh- No, pretty simple. You just arrange something like the mat in the center of the tank on a structure or stretched from wall to wall, where the propellant concentrates. Very easy to do and more effective than all the baffling and one way openings they use now.
post #7 of 7 Old 12-13-2014, 03:16 PM Thread Starter
What amazes me about this stuff is the apparent lack of air in the lines as it's wicking the fuel up.
Wonder how well it would work for a dry sump application?
