308 QV Porn - Ferrari Life
post #1 of 27 Old 08-06-2014, 10:41 AM Thread Starter
Ferrari Life Posts: 86
308 QV Porn
Hello and good to be back.... I have the next few months off and really want to get this ferrari QV done. In the end the Paxton supper charger didn't fit. Im now going with a KKK 27 turbo, water to air intercooler, Tial Bov and waist gate, Tec GT to run it with a AEM wide ban o2..
masonfamily04 is offline
post #2 of 27 Old 08-06-2014, 10:43 AM Thread Starter
Let me know what you guys think..
post #3 of 27 Old 08-06-2014, 11:16 AM
Ferrari Life Posts: 11,866
Looks great. Now you need some black crackle paint on the aluminum air intake.
Rust on the rotors is always a sign she needs to be driven. Or that you need ceramic brakes.
post #4 of 27 Old 08-06-2014, 11:20 AM
Ferrari Life Posts: 9,567
wetpet is offline
post #5 of 27 Old 08-06-2014, 11:27 AM
Ed- Affirmative, and that waste-gate is going to make some lovely sounds.
post #6 of 27 Old 08-06-2014, 01:15 PM Thread Starter
The crank pully is off of a 348 and the water pimp pulley is off of a 360. So now I have a 6 rib setup.
post #7 of 27 Old 08-06-2014, 06:03 PM
mk e's Avatar
Ferrari Life Posts: 4,439
NICE!
Great to see it coming together....my how childern slow things down huh?
Has it run yet?
mk e is offline
post #8 of 27 Old 08-07-2014, 04:33 AM
Badkarma308's Avatar
Well done man. Looks good.
Badkarma308 is offline
post #9 of 27 Old 08-07-2014, 05:50 AM
bretm's Avatar
Ferrari Life Posts: 2,152
Awesome!
bretm is offline
post #10 of 27 Old 08-07-2014, 06:37 AM
Pizzaman's Avatar
Ferrari Life Posts: 1,577
I likey.
Pizzaman is offline
post #11 of 27 Old 08-07-2014, 01:48 PM Thread Starter
My electric oil pump showed up today. Going to use it to scavenge the turbo and pump the oil threw a cooler. Where should I drain the oil to??? Mark, kids do slow down the projects but I wouldn't change it for the world. Thanks for the positive comments and its good to be back in the shop.
post #12 of 27 Old 08-08-2014, 12:17 AM
I remember seeing a fitting in the block in Bret's thread where the oil separator drains to, that would probably be a good place to return turbo oil. Not sure a cooler on that return line would be worth the trouble to install, as there will not be a huge volume of oil flowing through it.
post #13 of 27 Old 08-08-2014, 02:34 AM
barcheta's Avatar
Ferrari Life Posts: 1,875
I'm in love! More pics please! That's a pretty meaty spacer you have on that rotor! Crazy offset.
Current: 85' GTS QV
barcheta is offline
post #14 of 27 Old 08-08-2014, 08:39 AM Thread Starter
Are you talking about draining the oil back by the dip stick?? What about the breather hole by the drop down gears. Paul where are you buddy?? Thanks again guys, it's good to be back!
post #15 of 27 Old 08-08-2014, 09:59 AM
This is what I was thinking of, bottom picture.
Originally Posted by bretm View Post
The last project for that weekend was to make a plug for the crankcase vent on the oil pan. A 3/8" bolt and a few minutes on the lathe did the trick.
I'm running a set of crank vents that are basically one-way valves mounted on the valve covers. You can see them in the pics above - the polished aluminum cylinders running horizontally.
I don't think you really gain much from them performance wise, but it's nice to eliminate some of the hoses that are all over the stock engine compartment.
Ahh, picture didn't quote, here it is: http://www.ferrarilife.com/forums/pr...i-pistons.html
Post #17
Last edited by Badkarma308; 08-08-2014 at 10:01 AM. Reason: Added link to find pictures
post #16 of 27 Old 09-10-2014, 06:47 AM
P2164's Avatar
Ferrari Life Posts: 1,194
Wow! I just found this, I've been out of pocket for awhile. I like what I see! How did you get the oil to drain back to the engine sump from the turbo? Are you using an electric pump?
A bunch of stuff.
P2164 is offline
post #17 of 27 Old 09-10-2014, 07:04 PM Thread Starter
Yes I had to use a pump...
post #18 of 27 Old 09-10-2014, 07:06 PM Thread Starter
Turbo oil pump
post #19 of 27 Old 09-10-2014, 07:24 PM
Ferrari Life Posts: 327
Im impressed,308 projects are very tricky and elaborate, for sure expensive. Forza
reggazz312t is offline
post #20 of 27 Old 09-10-2014, 08:02 PM Thread Starter
I had a lot of help from some great people on Ferrari life. This is the oil pan I made for the turbo.
