348 motor - front engine / RWD conversion - Ferrari Life
post #1 of 110 Old 05-18-2013, 07:18 AM Thread Starter
Ferrari Life Posts: 65
This will be my ongoing build thread to make a 348 motor work in a front engine car and rear wheel drive.
I am adapting a Ford bell housing and a Borg-Warner T5 transmission.
With the help of a friend (with a large CMM unit) I was able to measure the block and bell. I have created the CAD file for the adapter plate and I am sending that off for machining.
Other plans I will be documenting in this thread
355 crankshaft
Cylinder head work. Big valves, shim under, cams, porting
EFI with a Lancia Thema intake
etc
Stay tuned
Reed H
Speedmade is offline
post #2 of 110 Old 05-18-2013, 08:56 AM
Pizzaman's Avatar
Ferrari Life Posts: 1,577
Looks like a awesome project.
Good luck with it Reed.
Pizzaman is offline
post #3 of 110 Old 05-18-2013, 09:18 AM
Ferrari Life Posts: 11,866
Reed- Sounds like fun. Try and give yourself access to the cambelt so you do not have to yank the engine every 3-5 years. You can download a 348 workshop manual at ferraridatabase.com, plus other 348 tech data.
post #4 of 110 Old 05-18-2013, 12:54 PM
Ferrari Life Posts: 6,197
I am going to be most interested in your transmission adaptation . sounds like a very fun project , I'll be I don't know why but it sounds fun .
post #5 of 110 Old 05-19-2013, 07:04 AM Thread Starter
Thanks. I downloaded that years back. Before I started the tear down.
I'm going to run the motor without belt covers. It should look pretty good.
post #6 of 110 Old 05-19-2013, 08:50 AM
a1exander's Avatar
Ferrari Life Posts: 1,094
Well done.
No half measures.
Look forward to the updates and please many many many pics.
a1exander is offline
post #7 of 110 Old 05-19-2013, 10:42 AM
Ferrari Life Posts: 256
interesting project , never realised the Thema manifold was so high !! great pic's .
Does it make any difference that the Thema did not have a flat crank ?
duck.co.za is offline
post #8 of 110 Old 05-19-2013, 10:49 AM
Is the end of the crank bolt pattern the same as a Ferrari flywheel ?
post #9 of 110 Old 05-19-2013, 11:50 AM Thread Starter
I'm using a 355 crank in the 348 block with a custom flywheel.
I hoping the intake will work well. It's essentially just long runners, with plenums and two throttle bodies.
I'm going to port the runners and have the whole upper section Extrude Honed.
post #10 of 110 Old 05-19-2013, 12:02 PM Thread Starter
Here are the stainless exhaust flanges I had made.
So I can build headers someday.
post #11 of 110 Old 05-19-2013, 12:48 PM
Ferrari Life Posts: 310
The manifold is tuned to 215 hp @ 6750 rpm with 2927cc. It's a dual length if I remember correct, one long and one short runner for each cylinder. Are you going turbo or supercharged? Rgds/Thomas
C311 is offline
post #12 of 110 Old 05-19-2013, 03:40 PM Thread Starter
I have a late Thema intake. The runners are equal length from the plenums to the intake port.
post #13 of 110 Old 05-20-2013, 01:58 AM
That one is better. Rgds/Thomas
C311 is offline
post #14 of 110 Old 05-20-2013, 04:27 AM
P2164's Avatar
Ferrari Life Posts: 1,194
Not sure about running without those covers, all it takes is a pebble to get between the belt and pulley and then a major boom boom. Hey didn't I just read this on the 40 site?
A bunch of stuff.
P2164 is offline
post #15 of 110 Old 05-20-2013, 04:33 AM Thread Starter
Yeah. I thought that crowd might be interested too.
post #16 of 110 Old 05-30-2013, 11:37 AM
Ferrari Life Posts: 429
355 crankshaft
etc
Stay tuned
Reed H
Would you be willing to share your CMM data for the Ferrari block pattern(s)?
Good luck with the project!
What chassis is it going into?
The dry sump will allow you to mount the engine very low in the body, but in that case the flat bottomed oil pan will potentially interfere with the front suspension crossmember. Also, mounting the engine as low as the dry sump allows will put the maximum width across the cylinder heads low enough that it may interfere with the front frame rails.
I @$$ume you're using the Lancia manifold for hood clearance?
Of course the packaging details are totally dependent on what body you want to put it in...
post #17 of 110 Old 05-30-2013, 05:25 PM Thread Starter
I'm not really worried, I have been running open belts on my Ducati's for years. Doesn't mean it can't happen though. I'm going to build some small guards up near the pulleys.
Plus I didn't get any of the original 348 belt covers or rear plates. And I don't want to spend the money to get them.
post #18 of 110 Old 05-30-2013, 05:31 PM Thread Starter
I will be putting the motor/trans into a Lancia Fulvia. Yes, you read that correctly. I am converting a Fulvia to front engine - rear wheel drive.
I am building a tube frame and using Ford suspension and drive line. Mustang II street rod parts up front, and Fox body Mustang rear axle and suspension narrowed to fit in the car.
I'm using the Thema intake as much for the lower height, but also because I didn't get the 348 intake system with my motor.
post #19 of 110 Old 05-30-2013, 06:25 PM
Fulvia? If you were in VA, I'd ask if this is your car...
I saw it at a Cars & Coffee in Northern VA.
Too many self-indulgent wieners in this town with too much bloody money!
post #20 of 110 Old 05-30-2013, 07:31 PM
A Fulvia with a V8 will be a real sleeper. Like my friend that had a 283 in a Bugeye Sprite.
