modify 360 wheels to fit 328 - Ferrari Life
post #1 of 4 Old 07-02-2012, 01:57 PM Thread Starter
Want to know if anyone has modified 360 wheels to fit a 328 or if it can be done? I'd also like to modify rotors and calipers if possible but not neccesary.
BillElliott328 is offline
post #2 of 4 Old 07-02-2012, 04:25 PM
Ferrari Life Posts: 11,866
Bill- Welcome to FerrariLife. See if this helps. Think those are 360 wheels, but they could be 550s, I guess. Narrowed to fit.
http://www.ferrarilife.com/forums/pr...-throttle.html
post #3 of 4 Old 07-02-2012, 06:00 PM
mk e's Avatar
Ferrari Life Posts: 4,439
I'm pretty sure 360 fronts will work all around with no issues.
If you want to use the wider 360 rears you either need to narrow them or you can get away with just a small OD aftermarket spring/shock setup and maybe a spacer.
I did 550 wheels on my 308 which are a little wider and of course I did it the hard way in the rear....I moved the lower shock mount so I could keep the 10.5" wheel inside the fender.
mk e is offline
post #4 of 4 Old 07-06-2012, 01:01 PM
Ferrari Life Posts: 429
Do you have a picture of your setup for this?
I'd like to upgrade my wheels eventually... after the car's running with the new engine.
