308 timing belt tensioner info needed - Ferrari Life
post #1 of 5 Old 01-07-2008, 07:54 AM Thread Starter
Ferrari Life Posts: 5
I'm new to Ferrari's (up to now I had only 1960's Porsches) so bear with me. I'm doing the 30,000mi service and am preparing to change the timing belts and tensioner pulleys. I can't find any info on resetting the tension. Should the engine be in a certain timing position (such as 0 degrees)? Should the pulleys be able to be rotated using finger power? Now, the left pulley can be rotated and the right one is tight.
Thanks for any help, Tony
Tony308QV is offline
post #2 of 5 Old 01-07-2008, 10:05 AM
Ferrari328GT's Avatar
Ferrari Life Posts: 366
Timing Belts
The service manual covers this pretty well, and I recommend that you get one if you are going to do your own service. Basically, though, it states that you put the belts on at TDC #1, rotate the engine twice in the direction of rotation, and tighten up the tensioners. Pretty straightforward. -Steve
Ferrari328GT is offline
post #3 of 5 Old 01-07-2008, 11:03 AM
Ferrari Life Posts: 298
You can download a copy of the workshop manual from:
http://www.ferrarilife.com/members/workshop.php
Resources: Parts List | Buyer's Guides
williamtaylor is offline
post #4 of 5 Old 01-07-2008, 01:18 PM Thread Starter
I have the workshop manual but didn't find that detail. I'll look through it again. I have downloaded the version from ferrarilife.com and will see if it is a different version than I have.
Thanks, Tony
post #5 of 5 Old 01-07-2008, 01:38 PM Thread Starter
Found it. On #1 at TDC the tensioners when unloaded release to the correct tension automatically. Just tighten the bolt and it's done.
Much thanks, Tony
