308 Help! - Ferrari Life
post #1 of 1 Old 12-26-2007, 03:08 AM Thread Starter
Ferrari Life Posts: 29
308 Help!
After a great drive in the hills (some 26 degree climbs) and a bit of 4 x 4 in the gravel sections of the 80 mile route, dodging some kangaroo's and a two metre long goanna. I arrived home to check over the engine (as I do after a drive), I attempted to open the engine compartment with no luck.
So I guess, I have finally broken something on the 308.
Thankfully, it isn't major. I have snapped the engine compartment release cable. I thought I remembered reading a thread about this before, but couldn't find anything in a search.
I have taken out the lever mechanism to find that the cable has snapped off at the solid connector.
Q1. Is it possible to reattach another connector? or is it a cable replacement?
Q2. If it is a cable replacement, There are two cables (I assume one is the emergency one below the seat belt and the other the main release), by having a bit of a tug of the cables, I couldn't determine whether it was the top or the bottom one that has snapped. Is it standard that the top or bottom is the main cable?
Any help appreciated.
Regards
Argento308
argento308 is offline
