Ferrari Life
-   Pre '99 V8s: GT4, 308, 328, 348, F355 (https://www.ferrarilife.com/forums/pre-99-v8s-gt4/)
-   -   328 Coolant leak (https://www.ferrarilife.com/forums/pre-99-v8s-gt4/7096-328-coolant-leak.html)
racerx 12-24-2007 11:05 AM
328 Coolant leak
I have a 328GTB and I think that when it gets a little hot coolant comes out of the overflow tube onto the driveway. I'm not sure if this could be an issue with the coolant tank cap or not. Any thoughts?
Boxer 12-25-2007 08:07 AM
It sounds like the system has been overfilled.
Magnum6464 12-25-2007 07:54 PM
Yup...too much coolant
volkster999 12-28-2007 02:41 PM
328 leak
I had the same issue with my 328. It turned out to be the 21 year old cap.
Gar 02-01-2008 02:23 PM
Radiator air bleed
You can try bleeding the radiator.
Open the front bonnet and at the top of the rad (can't remember which side), there is a small thumbwheel tap.
With the car warmed up and engine off, unscrew the tap and bleed out the air until coolant is expelled. Shut the tap and you're good to go !
Best Regards,
Gar.
2 x 328GTS (one in UK, one in USA)
