1977 308 Gt4 non stock timing belts please help ! - Ferrari Life
post #1 of 10 Old 05-27-2007, 04:38 PM Thread Starter
Ferrari Life Posts: 5
I am not able to find the timing belts to raplace on my 308.
They are not stock ( see picture ) can anybody help ?
Alessandro
lisander is offline
post #2 of 10 Old 05-28-2007, 09:01 AM
Ferrari328GT's Avatar
Ferrari Life Posts: 366
Belts
Is there some reason you don't want to go with the stock belts? They are actually quite inexpensive. -Steve
Ferrari328GT is offline
post #3 of 10 Old 05-30-2007, 05:39 AM Thread Starter
To install stock belts i should replace 6 pulleys and 2 tensioners.
And it's VERY expensive !
lisander is offline
post #4 of 10 Old 05-30-2007, 07:33 AM
Ferrari Life Posts: 167
you got to pay to play man...half assing it now will only lead to permature failure down the road and that is the last thing you want to fail...rebuilding that engine will cost way more then replacing the tensioners and pullys...
the head is offline
post #5 of 10 Old 05-30-2007, 06:32 PM Thread Starter
I know.. I know.. but my pulleys and belts are far better than stock.
I don't like to spend many go backward ...
lisander is offline
post #6 of 10 Old 05-31-2007, 07:57 AM
who's system are you using (hill engineering?)
The photo looks like the pullys are very similar to the drysump cogged belts on a formula ford/formula 1500 you may want to look at pegasus racing http://www.pegasusautoracing.com/ those guys have everything
the head is offline
post #7 of 10 Old 06-04-2007, 08:38 PM
dinogt4guy's Avatar
Ferrari Life Posts: 177
How are the pullys differn't than stock? Diameter? # of teeth? Whats is exactly the differance? Be very specific.
There is nothing like a Ferrari, there never has been and never will be!
dinogt4guy is offline
post #8 of 10 Old 06-07-2007, 11:12 AM
Ferrari Life Posts: 6,196
I do know of a person in Sacramento that has similar belts on his 308 which he also designed for a 328 in his CAD SC kits.
pm/email me and I'll put you in touch with him.
but those belts DO look worn...be careful...
post #9 of 10 Old 06-07-2007, 04:16 PM
Ok , they are standard industrial timming belts ,, try an industrial bearing company , they should have a next day service , all you need is the , belt width ,number of teeth ,tooth pitch .
mcliff watts is offline
post #10 of 10 Old 06-12-2007, 04:14 PM Thread Starter
Thanks you all ,
here attached is a better drawing i took from the pulleys.
I think it's a standard HTD profile and discovered it was designed by GoodYear in 1976.
I am wayting for an answer from Gates they are very nice and competent !
I think i will install PowerGrip GT2 960-8MGT-30 or may be better matching PowerGrip HTD 960-8M-30 industrial products. They should be rated for 20000 rpm. Any draw back ?
thanks again...
alessandro
lisander is offline
