208/308 GTB handbrake - Ferrari Life
post #1 of 2 Old 05-13-2007, 11:45 PM Thread Starter
Ferrari Life Posts: 8
Hi,
Is your GTB handbrake efficient?
The mine not at all...in spite of new pads.
Any idea what I can do:confused?
Many thanks for your answers
sylba
sylba is offline
post #2 of 2 Old 05-14-2007, 12:36 AM
Pete04222's Avatar
Ferrari Life Posts: 5,509
Mine was bad until I adjusted it. The adjustment is just behind the muffler, on the parking brake cable. It is somewhat difficult to get to. Follow the cables and you'll see the adjustment nut. Figure out what combination of tools you will need. As I recall the nut itself is a 10mm but I can't recall what I used to get to it.
Pick both rear tires up off the ground, give the handbrake 3 clicks and then tighten the adjustment until you can't turn the tires by hand. Perfect.
Capt. Pete
Pete04222 is offline
