308 GTSi Oil Pressure Gauge - Ferrari Life
post #1 of 7 Old 03-31-2007, 04:49 PM Thread Starter
Tifosi's Avatar
Ferrari Life Posts: 62
My oil pressure gauge reads constantly low, I have a new pressure sensor ordered and will replace it in hopes of remeding the issue. On the other hand it could be the gauge, does anyone know the operating voltage of the sender to gauge? i.e. I assume as the presuure increases the voltage to the gauge does as well, can anyone confrim this. Thanks
Tifosi
1980 Ferrari 308 GTSi
2002 Mercedes Benz C32 AMG
2004 Triumph Bonneville - Cafe Racer
Tifosi is offline
post #2 of 7 Old 04-01-2007, 04:50 AM
Ferrari Life Posts: 293
Summary of Veglia requirements:
Oil pressure:
Full scale 68 ohms to ground.
Top of red area 360 ohms
Zero PSI 470 ohms
(Reverse scale due to meter mounting upside down)
Temperature:
Bottom of red area 19.7 ohms
Bottom of scale 198 ohms
Fuel
Full 44.5 ohms
? 134.5 ohms
Top of red area 276 ohms
Empty 376 ohms
Voltage
Left end 11.22 Volts
First tick 12 Volts
Second tick 14.6 Volts
Right end 17.7 Volts
enjoythemusic is offline
post #3 of 7 Old 04-01-2007, 08:38 AM Thread Starter
Tifosi's Avatar
Excellent - Exactly what I was looking for, luckily I have a resistence simulator for work so will test it out. Thanks very much!!
Tifosi
Tifosi is offline
post #4 of 7 Old 04-02-2007, 09:59 PM
bernardo66's Avatar
Ferrari Life Posts: 18
Odds are, it's your sensor that's faulty, and not the gauge. I just changed mine, and it reads perfectly.
La storia si scrive con un pizzico di realtÓ e molta fantasia
Enzo Ferrari
bernardo66 is offline
post #5 of 7 Old 04-03-2007, 02:21 PM
Palo Alto in California can rebuild your guage.
post #6 of 7 Old 04-03-2007, 06:26 PM
bernardo66's Avatar
I changed my sensor...not my gauge.
Enzo Ferrari
post #7 of 7 Old 04-05-2007, 10:05 PM
Good for you, but guages DO go bad from time to time.
