1982 308 GTSi Timing Marks - Ferrari Life
post #1 of 3 Old 12-03-2006, 07:02 AM Thread Starter
Ferrari Life Posts: 7
I'm converting to a new electronic ignition and I'd like to know how to set cylinder 1 TDC. From reading articles it sounds like there are Cam, Crank, and Flywheel marks. Which is the best or easiest to use?
Gadgetman is offline
post #2 of 3 Old 12-03-2006, 10:05 AM
Ferrari328GT's Avatar
Ferrari Life Posts: 366
The most accurate way to set timing is with the flywheel marks. Unfortunately, the marks are really hard to see, but they are there. PM 1-4 is TDC on the rear bank, and PM 5-8 is TDC for the front bank. It took me at least an hour to find the marks, and use some white-out on them so that I could see them with a timing light. I have tried to upload a picture of the flywheel marks, but don't seem to be able to do it. If you need one, I can email it to you. Good luck. --Steve
Upload problem fixed. Thanks Enzo250GTO.
Ferrari328GT is offline
post #3 of 3 Old 12-03-2006, 06:15 PM Thread Starter
Timing Marks
That's great. I figure with the timing mark set on the flywheel and the rear distributor rotor pointing at cylinder 1 then I can cold set everything from there. Once the ignition is running then we'll worry about dialing it in a bit. I appreciate the response.
