F355 CAM LOCKS for Ferrari 355 - Page 2 - Ferrari Life
post #21 of 26 Old 02-26-2016, 10:18 AM Thread Starter
Ferrari Life Posts: 1,872
post #22 of 26 Old 02-26-2016, 05:23 PM
silly's Avatar
Ferrari Life Posts: 269
Yeah Babay !!!!!
94 F348 Challenge
95 F355 Challenge x 2
97 F355 Spider
silly is offline
post #23 of 26 Old 02-29-2016, 02:39 PM
Ferrari Life Posts: 5
Cam locks arrived today Dave and they look great! Thanks for providing these.
Sent from my SM-G900V using Tapatalk
seattlem5 is offline
post #24 of 26 Old 02-29-2016, 03:10 PM Thread Starter
Thank you very much for your support, Ettore
Other cool stuff in development too I designed 4 more Ferrari tools this weekend
post #25 of 26 Old 04-03-2016, 02:35 PM
Ferrari Life Posts: 15
cam locks
Dave ,
I checked out those cam locks, and I think they look great. And they should serve their function well I might add. My only question is; in order to install the tool with a "worn" belt, will the pins line up, or will one need to tweak each cam into the tooth? Thank you. -John
iceman is offline
post #26 of 26 Old 04-03-2016, 04:10 PM Thread Starter
Hi John,
I'm going to add more info to our website soon as there is a bit of confusion and misunderstanding on how these function.
First, I designed these primarily to hold the cam pulleys in order to loosten and tighten the cam pulleys. In order for these to fit, the relationship of each cam pulleys to the other is specific and critical. Based on belt slack or tension, it may be required to rotate one cam very slightly with relation to the other to get the tool engaged.
For a "lock and swap" of belts, please note the engine does not need to be at TDC. Orient the cam pulleys per the image below, install the tool to lock the cams, lock the crank, remove and replace belts. Note, because of cam timing, you may only be able to lock one bank at a time.
The other option is to flip the main body and not engage the pins and just use the tool as a pure clamp. This will not resist torque on the bolts this way though.
Feel free to contact me if you have other questions. Thank you.
