F355 Replaced fans today - Ferrari Life
post #1 of 13 Old 10-11-2015, 09:50 PM Thread Starter
Taz355's Avatar
Ferrari Life Posts: 379
Replaced fans today
So i thought i would replace my fans to the new spal sealed unit before they become unavailable. Easy task and i will post the fan number later.
Remove rear wheels.
Remove inner fender liner.
Remove 4 10mm bolts
Remove fan
Remove rubber from old fan.
Now the extras
Remove wires from old fan to aid in getting clip off to install on plug for new fan.
Remove wires from new fan and install clip, replace wires, then replace fans.
To remove the plugs insert a small device inside plug pushing down on the Inside of the U shape of each wire. This needs to be done to staighten out the retainer tab so the wire pulls out. See pics.
Taz355 is offline
post #2 of 13 Old 10-11-2015, 09:52 PM Thread Starter
Taz355's Avatar
Plug and clip that needs to be attached.
Taz355 is offline
post #3 of 13 Old 10-11-2015, 09:53 PM Thread Starter
Taz355's Avatar
Final pic put together with tab connected and slid over.
Taz355 is offline
post #4 of 13 Old 10-12-2015, 10:11 AM
lotusk's Avatar
Ferrari Life Posts: 159
More info on fan number please
More pics please
Thanku
lotusk is offline
post #5 of 13 Old 10-13-2015, 04:52 PM Thread Starter
Taz355's Avatar
Tfan number pic 1
Taz355 is offline
post #6 of 13 Old 10-13-2015, 05:00 PM Thread Starter
Taz355's Avatar
Fan pic 2
Taz355 is offline
post #7 of 13 Old 10-13-2015, 05:01 PM Thread Starter
Taz355's Avatar
No pic for install or removal because if you follow instructions its very easy.
Taz355 is offline
post #8 of 13 Old 10-13-2015, 09:21 PM
lotusk's Avatar
Thanku
lotusk is offline
post #9 of 13 Old 10-20-2015, 04:44 AM
Ferrari Life Posts: 94
Where did you buy the fans?
badabing is offline
post #10 of 13 Old 10-20-2015, 09:21 PM Thread Starter
Taz355's Avatar
I found the fans on ebay from a usa supplier. I forget the name. Sorry. They were not that easy to find. For the few hundred bucks i would just start searching, i am not sure they r still making them. Not as easy tO get as they were five years ago. I kept my old ones as spares.
I forgot ebay keeps the sellers info. It was CVEXCHANGE
Taz355 is offline
post #11 of 13 Old 10-25-2015, 02:06 PM
Ferrari Life Posts: 74
thanks for the info Taz. I did a quick search and found some that have the same part # but appear to turn in the wrong direction based on the description.Is that posible? Did you run across this?
https://advancedsportvehicles.com/sp...w90-mp280.html
ernest
emac is offline
post #12 of 13 Old 10-26-2015, 12:14 PM Thread Starter
Taz355's Avatar
Mine blow
Taz355 is offline
post #13 of 13 Old 11-03-2015, 01:27 PM
Update, the link from advancedsportvehicles.com is the correct fan. He has them in stock if you need them. his description is wrong.
emac is offline
