F355 355 F1 Fuses and Relay not listed in manual or WSM - Ferrari Life
post #1 of 6 Old 09-05-2015, 04:23 PM Thread Starter
Ferrari Life Posts: 1,873
Big thanks to Grant for tipping me of in this thread:
http://www.ferrarilife.com/forums/pr...f1-failed.html
I started this new thread so folks could find it easily.
Behind the passenger foot rest (lower right corner) 2 addition fuses and 1 relay are for the F1 system. From a brief scan of the owners manual and WSM, I do not see these listed. But, I may just have missed it....
The 2 fuses are larger Maxi Blade fuses. One is a 20 amp and the other is a 40 amp.
The relay is common with others used in the car, it's Bosch 0 332 019 103
post #2 of 6 Old 09-05-2015, 04:24 PM Thread Starter
post #3 of 6 Old 09-05-2015, 04:25 PM Thread Starter
post #4 of 6 Old 09-05-2015, 04:26 PM Thread Starter
post #5 of 6 Old 09-10-2015, 08:38 PM
Taz355's Avatar
Ferrari Life Posts: 379
You got it Dave the other thing that should be mentioned is the plug to the F1 pump at the back can also be an issue. If the fuse goes itmcan also be the plug as the issue not the f1 pump. What i did to find it was i turned the key to position 1 and the f1 pump did not kick in.
Then i went to the back and wiggled the plug and instantly the pump came to life. I used the gold connector kit tools to remove the two connectors and replaced them with crimp connectors which were identicle for our kenworth truck gauges. No problems since.
Taz355 is offline
post #6 of 6 Old 09-10-2015, 08:40 PM
Taz355's Avatar
Here is a pic of the plug.
Taz355 is offline
