F355 Temperature measurements under CV Boot Shields - Ferrari Life
post #1 of 7 Old 08-23-2015, 02:29 AM Thread Starter
john85QV's Avatar
Ferrari Life Posts: 153
I had a change to log some temp data on my 95 with OEM shields which are covered with sheet aluminum cut to the same size and shaped as the OEM shields. The first picture shows the mounting of the thermocouple on the underside of the shield. It was mounted with a small piece of wood (1/8" thick) which was supposed to act somewhat as a insulator between the shield and the TC. This was located on the back side of the shield near the bottom edge.
The second picture shows the shields as installed on my car. Note that the back part of the shield is almost directly under the Y pipe.
Third figure shows the temperature data from start up, driving, stopping for gas, driving, stopping for lunch, driving home and cool down in the garage. Pretty much self explanatory. Time is in minutes from start up.
I hope to do another extended test with the TC mounted differently to better isolate it from contact with the shield.
95 F355 Spider SwatersBlu/tan
john85QV is offline
post #2 of 7 Old 08-23-2015, 08:47 AM
silly's Avatar
Ferrari Life Posts: 269
exothermic ~ endothermic
Nice to have some base.
This reminds me of work, think I need an ice pack and a vicoden
94 F348 Challenge
95 F355 Challenge x 2
97 F355 Spider
silly is offline
post #3 of 7 Old 08-23-2015, 11:18 AM
hjp
Ferrari Life Posts: 56
John,
From the photo, it appears your car has an OEM Y pipe which includes cats. Correct? Do you also have OEM primary cats or test pipes? Just wanting to check if this data represents a stock, all OEM cat equipped 355.
hjp is offline
post #4 of 7 Old 08-23-2015, 12:35 PM Thread Starter
john85QV's Avatar
Originally Posted by hjp View Post
John,
Y pipe is stock. Cats are Nouvalari sport cats.
john85QV is offline
post #5 of 7 Old 08-23-2015, 02:28 PM
hjp
John,
Forgot to ask, do you have stock heat shielded OEM headers or something else?
hjp is offline
post #6 of 7 Old 08-23-2015, 03:03 PM Thread Starter
john85QV's Avatar
John,
Stock headers. Stock Y pipe. Nouvalari cats. I doubt the type of cat make much, if any, difference except some OEM cats were shielded, some were not.
john85QV is offline
post #7 of 7 Old 08-24-2015, 08:02 AM
hjp
Agree. Thanks John.
hjp is offline
