F355 Anyone replaced their thermostat? - Ferrari Life
post #1 of 9 Old 08-15-2015, 10:00 AM Thread Starter
Taz355's Avatar
Ferrari Life Posts: 379
So i have taken this thing apart 4 times now and i think the leak is comming from the thermostat housing. Traces of coolant are solidified on the housing. My question is do others that have replaced it used two gaskets or one? Ricambi only shows one on their website and i only used one. It did seem kinda weird but i thought i was following the correct method. Here is a pic of both for a 308 so i know they use both.
Taz355 is offline
post #2 of 9 Old 08-15-2015, 10:01 AM Thread Starter
Taz355's Avatar
Is there a green gasket part number somewhere or should i try the 308 one?
Taz355 is offline
post #3 of 9 Old 08-15-2015, 01:54 PM
Hmmm....I can't recall the F355 using a gasket other than the square cut o-ring. That's all that is shown in the parts manual. I just did a 456 and it too used a seal ring versus a gasket.
post #4 of 9 Old 08-15-2015, 03:08 PM Thread Starter
Taz355's Avatar
Thanks David mine too just uses the split rubber over the thermostat but i know it is slightly leaking. Do you think it would hurt to put a thin gasket like that green one in. There. I do not want to over torque or break the studs trying to get it to seal.
Thaks for your reply.
Taz355 is offline
post #5 of 9 Old 08-15-2015, 05:10 PM
Grant, you shouldn't have to. Your split o-ring may just be over-compressed and need to be replaced (if you haven't done so, already.) The torque of those fasteners is only 6.5 lb-ft. Although a gasket probably be OK, I'd be more inclined to determine why she's leaky there and perhaps a touch of sealant around the split-ring would be more in order. I can tell you from fist hand experience with a similar set-up on a 456 (that drove me nuts) that if the seal ring isn't perfect, they will leak.
post #6 of 9 Old 08-15-2015, 05:24 PM Thread Starter
Taz355's Avatar
Ok. I did replace the seal and it is definately leaking less. Thanks
Possibly if i put on the gasket then the seal wont compress enough and that may cause more problems. Now that i think about it
Thanks again.
Taz355 is offline
post #7 of 9 Old 08-15-2015, 05:26 PM Thread Starter
Taz355's Avatar
If overtightening will make it leak i think thats what i did.
Taz355 is offline
post #8 of 9 Old 08-16-2015, 11:06 AM
Are you sure you're just not seeing a bit of seepage from when you cracked the bleeder on top of the thermostat housing?
post #9 of 9 Old 08-16-2015, 01:38 PM Thread Starter
Taz355's Avatar
Yes because the sepage was there before i tried bleeding it. I know those bolts are ovetorqued because the numbers you said are not verry high.
Thanks again.
I did snug up all connecting hoses and so far so good no leak but only driven two separate occasions. Time will tell.
Taz355 is offline
