F355 Turn Indicator Relay ('98 Spider/Euro) - Ferrari Life
post #1 of 6 Old 07-28-2015, 11:37 PM Thread Starter
Ferrari Life Posts: 5
G'day gentlemen
I've been trying to find the turn indicator relay on my Australian F355 Spider. I've tracked down a part number for the relay using an online catalogue, but would like some sort of confirmation (visual sighting of the part number) before purchasing this item. The P/N is 171798 for my right hand drive car (non-USA, post assembly number 24038).
I've found the unit which creates the *audio* for the turn, but not the actual indicator relay. There is one relay/unit close by to the audio generator, but it's wrapped in sticky disintegrating foam and hard to get to, so I don't want to go to great lengths to remove that and find out it's the wrong item. A previous forum post suggests it's under the carpet in the driver's footwell, but no luck finding it there.
When making a left hand turn, the flash speed sometimes varies. When the speed changes, the front left turn indicator stops working. I've cleaned the contacts on the bulbs (front and rear) and the lamp holders. I also discovered some cracked connector plugs on the front harness (and replaced the harness without success), and have been looking for other solutions. I'm not sure where the grounds/earths are for this system.
The only lamp I haven't removed is the small round one on the side of the car. I'm not sure how to remove that. Does it screw out?
Thanks for any feedback.
Best wishes
Ian.
Qavion is offline
post #2 of 6 Old 08-14-2015, 06:32 PM
Ferrari Life Posts: 124
Originally Posted by Qavion View Post
G'day gentlemen
Best wishes
Ian.
See this one:
Ferrari 213326 Direction Emergency Light Relay Valid for USA and CDN | eBay
jgelovani is offline
post #3 of 6 Old 08-17-2015, 05:41 AM Thread Starter
Thanks, but that's a US/Canada version. I needed a Euro version.
Don't ask me what the differences are, though
Qavion is offline
post #4 of 6 Old 08-17-2015, 08:59 PM
Sorry, but the European schematics and blinking timing are not any different from US/Canadian specs. However, I may be missing something...
Maybe someone on the forum can address this question?
post #5 of 6 Old 08-24-2015, 08:58 PM Thread Starter
I wish I knew the answer, too. I put the new official Ferrari UKP107 relay (P/N 171798) into the car today and instead of only the left side going fast, both sides went fast!
I refitted the old relay. Both side (left/right) indicators ran at the speed which I expected from a serviceable car (The left side did sometimes work ok before... It was intermittent). I swapped the old/new relays back and forth a few times, and always the same results (so it's not intermittent connections on the back of the relay).
I don't know if the part they sent me is faulty, or if the part number is wrong for my Australian car.
Cheers
Ian.
Qavion is offline
post #6 of 6 Old 08-24-2015, 10:06 PM Thread Starter
The answer may be in this message thread. An additional side marker light? The USA ones seem to have two rectangular side markers.
[360] turn signal flashers - FerrariChat.com
Qavion is offline
