F355 Intermittent no spark-misfire on the 5-8 bank - Ferrari Life
post #1 of 6 Old 06-03-2015, 04:31 PM Thread Starter
OBD-I car. This was a tough one to find, as there were no codes,and the SD-2 tester revealed no faults. I could see the trigger waveform on my Picoscope, but the signals were noisy and low in amplitude. All of the coil and ECU voltage and resistance tests indicated no problems. Yet, backfires were noted almost immediately after 10-15 seconds of running. Fuel pressure tested within specs. A compression test done and was within the normal ranges. So what's left? Sometimes, pictures do speak a thousands words. Note that this "stuff" is on the component end, not the harness side. During the recent major service, any corroded connectors/torn boots were replaced.
Soon to be happy client...and yet another F355 due in on Monday. Yes, you guessed it. The CEL is on.
post #2 of 6 Old 06-03-2015, 04:36 PM
Ferrari Life Posts: 1,872
Dave, I appreciate and I'm sure other will appreciate you posting this. Michael is going to be happy once he can drive the car
For anyone that does not know Dave, he is a stand up guy and always willing to help.
post #3 of 6 Old 06-04-2015, 11:47 AM
Ferrari Life Posts: 54
Nice find! Thanks for sharing the pic.
INTMD8 is offline
post #4 of 6 Old 06-04-2015, 01:20 PM
john85QV's Avatar
Ferrari Life Posts: 153
TDC/RPM sensor? Did you replace the sensor or just clean the contacts?
My buddy has a Toyota pickup. Same as mine but two years newer. We both had P0420 CELs, (Cat below efficiency). Mine from a crack exhaust pipe just after the cat letting air into the exhaust. His, a bad O2 sensor. It's not just a Ferrari thing.
95 F355 Spider SwatersBlu/tan
john85QV is offline
post #5 of 6 Old 06-04-2015, 03:26 PM Thread Starter
Yes, it was the 5-8 bank crank trigger. I cleaned it, but later replaced it. Lesser corrosion was found at the coil and coil amps. Again cleaned, but no need for replacement. I've had my fair share of cat efficiency codes. Sometime the diagnosis is easy, sometimes not so much...As I suspect you know quite well, the "code" rarely is the problem, but rather the "result of..:"
post #6 of 6 Old 06-05-2015, 07:12 PM
Ferrari Life Posts: 74
Thank you posting.
emac is offline
