328 over rev knock - Ferrari Life
post #1 of 3 Old 01-15-2006, 06:34 PM Thread Starter
Ferrari Life Posts: 45
328 over rev knock
Before we pull the engine out of this bad boy, does anyone have a better idea. Looks like somehting on the bottom end, but it does not sound like a connecting rod knock.
So far we have,
Compression check OK,
Valve springs OK
Valve Guides OK
Cams OK
Top of pistons OK
Pull oil pan, no debris
Engine must run over 500 RPM's before you hear the knock. Knock seems to be coming from cylinder #3 on the rear bank.
Any adivse would be appreciated,
Kelly
tifosi1 is offline
post #2 of 3 Old 01-16-2006, 06:32 AM
Ferrari Life Posts: 15,131
I once had a knock type problem on the F355. Turned out to bad spark plug. Changed the plug and the problem disappeared.
post #3 of 3 Old 01-16-2006, 11:17 AM
Magnum6464's Avatar
Ferrari Life Posts: 1,990
I've had the same problem, bad plug...change all of them before doing an engine out service.
8)
1990 348 TS (87284)
Magnum6464 is offline
