F355 Radiator fan passenger side. Help! - Ferrari Life
post #1 of 3 Old 05-06-2015, 09:44 AM Thread Starter
Ferrari Life Posts: 156
From looking at it I assume I have to unbolt the radiator to take the fan off? No way to hold the bolt heads on back while I undo the nuts. Is there a way to get passenger side header out without removing the radiator fan?
shootfighter65 is offline
post #2 of 3 Old 05-06-2015, 11:45 AM
The original bolts were captive and cannot turn due to them being locked in place by the radiator sheet metal. You should be able to spin those nuts off easily. I recently changed that fan on a 355 in very little time, including transferring "not-included" parts over to the new unit ....
Give it a try...
post #3 of 3 Old 05-06-2015, 01:18 PM Thread Starter
I had to buy a stubby 10mil wrench and contort my self into a position where I could hold it with 2 fingers. (Fan nuts and bolt). I thought about epoxing the bolts in place before I reassembl it in case I needed to remove cooling fan ever again. I ended up removing the oil cooler header fell right out. I will attach the fan before I put it back together. Now it's cleaning and some detailing until the new parts come in
