F355 F355 Propeller Shaft (need engineering specs or an affordable shaft) - Ferrari Life
post #1 of 7 Old 03-06-2015, 09:23 PM Thread Starter
Ferrari Life Posts: 138
I need part number 162909 propeller shaft. I would prefer to have the engineering specs but would settle for a propeller shaft that wasn't in the 4 digit price range. 348 prop shafts can be had for $250 or so, but they do not appear compatible with the F355, but I can't be sure about all the measurements until I remove my transmission and get the rest of the measurements on the F355 propeller shaft.
If I can get a good price on having the shaft made I hope to do a small run of them so that I can help others and have a spare as well. This part is no longer available from Ferrari and is extremely expensive if you are lucky enough to find one.
Markp is offline
post #2 of 7 Old 03-07-2015, 03:23 AM
Ferrari Life Posts: 1,872
Making these is not going to be easy. Are you positive they are no longer available? Did you contact a dealer or a parts reseller? If you did not contact a dealer, I suggest you try them.
post #3 of 7 Old 03-07-2015, 09:35 AM
Taz355's Avatar
Ferrari Life Posts: 379
They were available only a year ago but they were thousands.
Taz355 is offline
post #4 of 7 Old 03-07-2015, 10:22 AM
Ferrari Life Posts: 11,856
Ferrari thinks they are NLA unless there is some NOS lying around.
post #5 of 7 Old 03-07-2015, 11:01 AM
The dealers can access the inventory levels of other dealers (maybe not all...)
post #6 of 7 Old 03-07-2015, 08:40 PM
silly's Avatar
Ferrari Life Posts: 269
formula GT - TUNINGTEILE
94 F348 Challenge
95 F355 Challenge x 2
97 F355 Spider
silly is offline
post #7 of 7 Old 03-11-2015, 06:46 AM
Ferrari Life Posts: 156
Did you try Russ at Ferrparts.com? He has scrapped quite a few 355's
shootfighter65 is offline
