F355 Installing CAM covers - gaskets and sealant? - Ferrari Life
post #1 of 14 Old 02-12-2015, 11:06 AM Thread Starter
Ferrari Life Posts: 1,872
Greetings all,
So, what is the story with CAM cover gaskets? It looks like these come as one piece but need to be trimmed in the areas where the cams extend beyond the head.
I seem to recall reading that a sealant needs to be used in the corners?
Can someone confirm and maybe post a photo? The WSM has no specification on this.
Thanks in advance
post #2 of 14 Old 02-12-2015, 01:29 PM
Ferrari Life Posts: 2,196
Dave, when you trim the ends of the gasket to fit or butt up against the other gasket material on the end covers, the dabs of silicone in the corners serve to "weld" the two loose ends together and hold them in place when you tighten the cover down. The 550 WSM shows it fairly well, and the 575M WSM has actual pics.
The 550 WSM is free for downloading from ferraridatabase.com, but you might consider picking up a 575M WSM from Daniel @ Ricambi. It's worth every penny of the $125 or $150 that he charges.
post #3 of 14 Old 02-12-2015, 02:14 PM Thread Starter
post #4 of 14 Old 02-12-2015, 04:34 PM
Dave, here's a couple of pics from the 575M manual. It's far better than the old style manuals for pics & how to's.
post #5 of 14 Old 02-12-2015, 05:38 PM Thread Starter
post #6 of 14 Old 02-12-2015, 07:59 PM
Ferrari Life Posts: 11,856
A good photo is worth a 1000 words.
post #7 of 14 Old 02-13-2015, 02:05 AM
May as well post the initial part of the procedure:
post #8 of 14 Old 02-13-2015, 05:04 AM Thread Starter
Thanks Again, John. It's nice to also see an advancement to the WSM's.
post #9 of 14 Old 02-13-2015, 03:06 PM
Taz355's Avatar
Ferrari Life Posts: 379
I see i got to the party late looks like their pics are good. I know when i did mine i didnt use much silicone very similar to what their pics showed. Thw first time i did this i had to cleanup the engine a lot. The original owner had it serviced at a ferrari dealer and the mechanic put on a lot and their was silicone all over. I did doubke check the covers for being square and they were. I have never had leak issues.
Taz355 is offline
post #10 of 14 Old 02-14-2015, 11:32 AM
John, I'm trying hard not to come across as being sarcastic, particularly since you and I are friends... But, in all honesty, the last thing these manuals need are pretty pictures showing folks how to install gaskets and sealant. This sort of fluff is a given. Focused efforts need to be spent correcting the mountains of technical inaccuracies, inconsistencies and blatant errors that have existed for decades in the WSMs. Some of the 'apparent' translations are horrific and require very, very careful reading, even by seasoned pros, to figure out exactly what is to be measured, expected, desired result, etc. Other than the information contained within the older "Diagnostic Sheets" that most folks aren't even aware of and certainly not printed in the WSMs, the information that is provided is blatantly lacking on many fronts.
post #11 of 14 Old 02-14-2015, 11:58 AM
No worries David, your comments are always welcome, sarcastic or no , and I couldn't agree more on the inaccuracies and translations. In the old manuals I use the French as much or more as I do the English for the procedures.
post #12 of 14 Old 02-14-2015, 01:34 PM
C'est bon!
post #13 of 14 Old 02-22-2015, 07:40 AM
Taz355's Avatar
I use the french a lot when doing my own services as well.
"mon tabernac! "
Taz355 is offline
post #14 of 14 Old 02-22-2015, 08:23 AM
silly's Avatar
Ferrari Life Posts: 269
They are great at throwing up smoke screens.
Nothing an experienced quality oriented tech will have an issue sorting out.
Personally I only use the WSM to get an "opinion" Seems more fiction then anything LOL
As far Ferrari telling the truth. They could not if there life depended on it. It's there way of life.
94 F348 Challenge
95 F355 Challenge x 2
97 F355 Spider
silly is offline
