F355 Major service fluid plug kit? - Ferrari Life
post #1 of 15 Old 02-11-2015, 07:12 AM Thread Starter
Ferrari Life Posts: 1,872
OK, so after getting all kinds of fluid all over me and my garage, I thinking I should design a kit of plugs for a major service.
I was particularly loving the gas all over my hands last night - yeah, that was fun
Anyone already do this? It would be great to remove the lines and then screw on a cap. I used some plastic bags with wire ties but less than ideal....
post #2 of 15 Old 02-11-2015, 07:54 AM
Ferrari Life Posts: 2,196
Dave, I have an assortment of tapered silicone plugs and rubber caps (think vacuum caps) that I use and they work pretty well.
The threads on many of these lines can be tough to match and tougher yet to get a good seal. I did use threaded caps on my 550's fuel lines, but they were a bear to find.
Brake & clutch lines are even tougher with their weird double inverted hyperbolic convex/concave bubble flared fittings, etc. Even if you can find a threaded cap to match (usually an M10x1.0), the doggone cap will still leak because it undoubtedly will have the wrong flare configuration.....
So now, I just ram tapered plugs in the lines
post #3 of 15 Old 02-11-2015, 08:33 AM Thread Starter
Good idea, John. I do have some rubber plugs at my shop and for the last several days, I keep forgetting to bring them home
I made a note today
post #4 of 15 Old 02-11-2015, 09:03 AM Thread Starter
post #5 of 15 Old 02-11-2015, 12:19 PM
The fuel spillage can be minimized by starting with a low fuel tank level, if possible...and having the fuel tank cap off when cracking the lines. If not, "Speedy-Dry" works wonders.
post #6 of 15 Old 02-11-2015, 12:38 PM Thread Starter
I did not think to open the cap...
I only leaked about 2 shot glasses per side. I actually want to drain the entire tank because the car was sitting for 6 years and I'm not so sure about the integrity of the fuel...
post #7 of 15 Old 02-11-2015, 12:40 PM
I'm with you there; I need to drain the tanks on the 355 I'm servicing. I think the fuel is of similar vintage.
post #8 of 15 Old 02-11-2015, 12:43 PM Thread Starter
Dave, my 95 is a duel fuel pump car. I see no drain in the tank itself, but I do see a drain (I think) at the bottom of each pump - stupid question - that is a drain, right?
post #9 of 15 Old 02-11-2015, 12:59 PM
Use the pumps to pump out the fuel tank.
post #10 of 15 Old 02-11-2015, 01:02 PM Thread Starter
Call me crazy John but if the pumps have drains, I'd go that route - pumps are not going to get to the bottom...
post #11 of 15 Old 02-11-2015, 05:18 PM
5 VALV's Avatar
Ferrari Life Posts: 101
Dave,
Will you have to do anything with the fuel tank because the car has been sitting so long?
Robb
“We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm.” George Orwell
5 VALV is offline
post #12 of 15 Old 02-11-2015, 05:25 PM Thread Starter
Originally Posted by 5 VALV View Post
Dave,
Robb
No, it's an aluminum tank. As a preventative measure, I will probably replace the fill tube which is known to leak and start fires - ask Cuneo
post #13 of 15 Old 02-12-2015, 06:09 AM
Indeed, they are. Just be sure to replace the copper sealing rings when done...
post #14 of 15 Old 02-13-2015, 03:10 PM
Taz355's Avatar
Ferrari Life Posts: 379
I got plugs from these guys but all my docs are in cali so dont have the sizes
Caplugs - Home - Caplugs
This might help you on the next one. I did same thing with plastic bags on my first one. I also used combination of colored zip ties for all the plug connections. Ie red, blue, yellosw comnects to red,blue yellow. Etc worked good and gave me some confidence when reconnecting.
Taz355 is offline
post #15 of 15 Old 02-13-2015, 05:31 PM Thread Starter
Grant, Cap Plugs is located in Buffalo and I have a bunch of those at my shop but need bring them home until today.
