355 firing order question - Ferrari Life
post #1 of 3 Old 10-08-2005, 11:05 AM Thread Starter
Ferrari Life Posts: 6
hey guys, i was hoping somebody knows the firing order for the 355 and how the cylinders are laid out. i noticed when replacing the plug wires that the new wires from kingsbourne had the coil terminal numbers stamped on the coil end of the wires. well,,, as i was swapping them, those numbers did not match how the original set came off (measuring the length of the wires as they came off). i just want to make sure this is correct as the car surges(before new wires and after) from low to mid rpm.. 2k-5k and i want to eliminate this as a potential problem. thanks for your help!
f355alldaylong is offline
post #2 of 3 Old 10-08-2005, 11:20 AM
Ferrari Life Posts: 15,132
The firing order on a 95 F355 fitted with Bosch Motronic 2.7 is:
1-5-3-7-4-8-2-6
and did not change with the move to Motronic 5.2 on the later F355s.
The firing order is listed in the owners manual in Section C.
Good luck.
post #3 of 3 Old 10-08-2005, 11:22 AM Thread Starter
355
thanks for the reply.. owners manual, you say? did not think to check there first. lol! i'll check it out, thanks!
