F355 Project Restoration: 1995 F355 Berlinetta - Page 34 - Ferrari Life
 4Likes
post #661 of 760 Old 07-18-2015, 10:11 AM
Taz355's Avatar
Ferrari Life Posts: 379
Wow for only a four year older car than mine i dont understand how those could look that bad.
Taz355 is offline
post #662 of 760 Old 07-18-2015, 06:31 PM Thread Starter
Ferrari Life Posts: 1,875
post #663 of 760 Old 07-19-2015, 01:11 PM
vracer's Avatar
Ferrari Life Posts: 49
Rear shocks and emergency brakes removed tonight
Emergency brakes?? Boy, I'd sure hate to have to use them in an emergency. Mine won't hold on anything over 1-2 degrees, and I've been told, "They're all like that". Do you guys concur?
I'm at 5 years, and the engine is coming out this winter, so it would be a good time to "fix" this - if a real fix is really possible.
vracer is offline
post #664 of 760 Old 07-19-2015, 01:34 PM Thread Starter
Hi Richard,
The design seems pretty typical of other cars - I see now reason why it won't work. My 98 e-brake works well.
I suggest you reach out to Ken at Ferrari of Atlanta. A while back he was selling new 355 brake kits - all 4 new rotors and pads (not ebake parts) for $500.00. I bought a set for a spare before I had this car and now I will use those parts on this.
post #665 of 760 Old 07-19-2015, 01:39 PM Thread Starter
Rear spindle housings - before and after.
These where painted silver. They actually cleaned up pretty well with the ultrasonic but had some scraps so I blasted them. I think I might paint these again as I imagine the brake dust would stain the bare aluminum easily
Sadly, one (maybe both) wheel bearings are toast. I'm going to press them apart and see if I can rebuild. If not, Eurospares has them for a much better price than on this side of the pond.
post #666 of 760 Old 07-19-2015, 01:41 PM Thread Starter
Before and after (Ready for yellow zinc)
post #667 of 760 Old 07-19-2015, 02:52 PM
Taz355's Avatar
My ebrake will lock up the rear if you pull hard and fast.
Taz355 is offline
post #668 of 760 Old 07-19-2015, 02:54 PM
Taz355's Avatar
I think i might have to check those bearing on next years engine out. Did not check them in 2010 but everything turned smooth and felt ok without dismantle.
Taz355 is offline
post #669 of 760 Old 07-20-2015, 03:28 AM
As they should. That brake design works quite well, particularly when they are adjusted properly. Most are not...
post #670 of 760 Old 07-20-2015, 09:39 AM Thread Starter
Designed and built a new Clutch Cover removal tool. I'll give it a try tonight.
EDIT: Surface ground tip of set screw nice and flat to not mar mating shaft
post #671 of 760 Old 07-20-2015, 03:31 PM Thread Starter
post #672 of 760 Old 07-20-2015, 03:33 PM Thread Starter
Two.....(some light taps with rubber mallet around perimeter while tightening jack screw)
post #673 of 760 Old 07-20-2015, 03:33 PM Thread Starter
post #674 of 760 Old 07-21-2015, 01:45 PM Thread Starter
Toast spindle bearing. I think I can rebuild this. The bearing race of the hub is in good shape after clean up
post #675 of 760 Old 07-21-2015, 04:24 PM Thread Starter
Bearing removed from Pumpkin and cleaned up.
post #676 of 760 Old 07-21-2015, 10:46 PM
Taz355's Avatar
Looks good dave. Awesome just awesome. I think i will do some of those misc items this next engine out. I am getting pumped to do mine again now after all the insperation.
Ya baby!!!
Taz355 is offline
post #677 of 760 Old 07-22-2015, 03:05 AM
Perhaps... but, this is a very high risk repair and is not recommended. Even the slightest amount of axial play can result in serious problems. It's an odd design and likely why Ferrari only provides a complete assembly as a replacement item. Pricey, too!
post #678 of 760 Old 07-22-2015, 03:42 AM Thread Starter
Dave, Eurospares has them for about $1,000 each.
Not sure I understand your other comments - it's a design I've seen in machinery: it's just a spindle with integrated race, not really too exotic.
I'll perform proper due dilligence on this and report back. If the race of the spindle was damaged I would not even attempt but since it appears fine, reassembling a bearing should not be any diffferent than how it was done the first time.
I should clarify that by rebuilding I mean replacing the bearing, not repacking the existing.
post #679 of 760 Old 07-22-2015, 09:05 AM
silly's Avatar
Ferrari Life Posts: 269
Dave I know your going to a stock configuration. That does look like something I seen in Model T transmissions
Possibly a different bearing configuration? I don't know the force's off my head and it's early here brain is still sleeping.
We change the bearing style on Harley engine cranks to a timkin limiting side play and take the 2-300 or so HP they put down .
94 F348 Challenge
95 F355 Challenge x 2
97 F355 Spider
silly is offline
post #680 of 760 Old 07-22-2015, 11:08 AM Thread Starter
Tim,
I have a feeling you are mixing two post: one with the wheel hub bearing and the other with the clutch? - Correct?
